Extracting window parameters and listing overall window area per room/Space
Hi guys,
i hoping someone might be able to help me here, i think i’m nearly there but can quite get over the final hurdle.
i’m trying to extract the window data from an architects model.
ultimately i want to do this via a linked file, but for now i’m doing it in the architects model.
Ive got all my windows listed out per room, which is almost exactly what i need.
however this is listing the ‘Type’ and not necessarily the size.
Script%202
1/ if its possible id like the get the length and width values.
2/ get the area of each window
3/ get to total area of windows per room
4/ Have a list of rooms with total area of windows (but includes the rooms that have no windows - so have 0 value if there are no windows.).
I’ve tried a few different things but seem to fail at item 4. with the ‘empty lists’ disappearing once i do anything with the length and width values.
this will form part of a bigger script so i need all the rooms in the list.
any ideas how i can get this working?
Thank you.
Dan
windows test.dyn (14.5 KB)
window Test.rvt (1.8 MB)
Try searching the forums before posting a question. There are a lot of threads about this exact topic already.
Maybe my question is a little too long. I’ve been through lots of threads on this, windows, empty lists, null values etc.
I can get all the data i need, but every time i get to the end i get this situation.
Where i have room numbers and totals of window area.
just my lists are out of sync because i don’t have a 0 value to align with the room with no glazing.
5 rooms/4 areas.
if this has been answered already i cant seem to find it.
Ah. I apologize. I see what you’re saying now.
You can use List.Deconstruct to separate your Rooms from their windows. Any rooms without windows will have an empty list and therefore sum to 0.
Thank You @Nick_Boyts
perfect!
my initial post did over complicate things!
Don’t forget that if a post solves your problem to mark it a solution!
