Exporting IFC at the end of the script
This might be a too simple question:
I need my script to export the Revit model to IFC. But when I use Expot.IFC node, it will export the Revit model immediately upon run, not after the results from the script have already been implemented. What should I do?
I already tried using the last node of my script as an input to the node that exports to IFC to make it run last, still didn’t work.
Transaction.end might work, depends
Use Very Simple logic like this.
Connect your node, which leads to a model change, to the ‘waitfor’. Then, use any element(Ex: View, IFCVersion etc) in ‘passthrough’, which will be subsequently linked to the ‘ExportIFC’ node for exporting.
This node is available in archilab and clockwork.
