Exporting Dynamo to Revit
hi, its msabchev96 again. i couldn’t post more replies for the day, since i made the account today. I tried with that node the first time, but it still wouldn’t even show the geometry in revit 3d
if it doesn’t work like in this thread, maybe someone else can help
sadly, it doesn’t. i looked and tried everything i could find on forums and youtube before posting this thread
one advice:
try to keep your graph simple and don’t change direction when you are halfway there
it was pretty messy
start at the beginning and end and work your way to connect the two
when something doesn’t work delete it
when you finally have the mass visible in Revit use Tab-select to get to the faces you need when using floor by face.
good luck
okay, thank you for your time!
