HI all,
I am trying to export some data from my model to an excel file. The excel file is a template an the sheets are all pre-named (in this case AssetEquipment) and i owuld like to export the data to this sheet starting in Column C, second row (C2)
I have been trying to use Bumble Bee (Bb Data and Write Excel) but they are returning null values and i am not sure.
I am using Excel 2016
Dynamo Core 1.3.2.2480
Dynamo Revit 1.3.2.2480
Can you try using the regular excel node to see if this is an excel issue?
HI Jacob,
Yes, i can use the standard Write to File, the issue there is that it deletes the sheet in the template file. I cant do that. All i need to do is populate and existing excel file, not delete the existing sheets and headers. Apparently the Bumble Bee nodes will do this, just not for me
OK, so managed to work this out. It seems i had some conflicts with other / older packages. I did an un-install, install and it works like a champ now.
So, lesson for young players, make sure your packages are comparable and up to date.
Happy Days
Yes that is true. This is why I used to write to a ‘raw data’ sheet and refer the ‘printing’ sheet to the values in the cells there.
