Hi All,
Is there any way Dynamo would be able to export mark/comment parameter as layers when exporting to dwg? Thanks
You’ll have to be a bit more specific, do you mean the parameters tags?
more importantly, why are you trying to export the mark parameter as a layer? What do you propose to do with this layer of nothing but data in AutoCAD? For sure we need some better explanation or some screen captures to show your intended work flow.
Revit IDs are embedded in elements’ Xdata when exported to AutoCAD. You could write a text file of IDs plus whatever parameter values and put it back together in AutoCAD using AutoLISP.
