Hi
I thought I could use the “Export View Set To DWG” principle for sheets, but it doesn’t seem to work. I didn’t get an error from @Konrad_K_Sobon’s script, but I didn’t get any DWGs either. Or maybe someone knows a plugin that can get this done?
Can someone tell me if what I’m attempting is possible and if so, what I’m doing wrong?
Cheers!
You feeding already a list of elements so there’s no need in List.Create. If you remove it, it should work.
Thanks, that work as I guess it was intended, but not how I expected it to. I was expecting a single DWG file. Is this possible?
All this script does it’s automating export function from Revit itself. Combining is not possible as far as I know.
