Hey all,
I have a weird problem.
I am using the Export DWG in Document node from the GeniusLoci package @Alban_de_Chasteigner to print multiple sheets to DWG.
It makes the DWGs with the correct name and saves them in the correct folder but there is a traceback error.(No yellow color though)
For some reason i am unable to copy the text message but here it is:
I dont understand the error as the DWGs are named and saved as they are supposed to…
<Workspace Version="1.3.4.6666" X="-176.028182239761" Y="-162.331491776084" zoom="0.620250220907471" ScaleFactor="1" Name="Export DWG in Document" Description="Export views to DWG with export setup in the active or given document.
Based on a script by Konrad K Sobon." ID="ed797c61-4f58-4b52-92c5-d8279f0e1b82" Category="GeniusLoci.CAD Export">
<NamespaceResolutionMap />
<Elements>
<PythonNodeModels.PythonNode guid="f6054804-ffcd-46d1-992a-67ede8500c2c" type="PythonNodeModels.PythonNode" nickname="Export DWG from directory" x="795.75511775548" y="549.937564360912" isVisible="true" isUpstreamVisible="true" lacing="Disabled" isSelectedInput="False" IsFrozen="false" isPinned="false" inputcount="8">
<PortInfo index="0" default="False" />
<PortInfo index="1" default="False" />
<PortInfo index="2" default="False" />
<PortInfo index="3" default="False" />
<PortInfo index="4" default="False" />
<PortInfo index="5" default="False" />
<PortInfo index="6" default="False" />
<PortInfo index="7" default="False" />
<Script>#Based on a script by Konrad K Sobon, @arch_laboratory, http://archi-lab.net
# Import Element wrapper extension methods
This file has been truncated. show original
Hi @Garbage_Collector ,
You’re maybe using nested lists or one of your views is a Null value.
No need for the content of the python script. A full image of your graph with the previews under the nodes would help a lot more
It is not possible to help you better at the moment.
Hi Alban,
Thank you for your quick reply!
You certainly pointed me in the right direction
The problem was that one sheet was being sent twice (because of a sheet size filter sending it via two different A3 size filters)
I changed the filters to only pass the correct size and now the error in the DWG node is solved.
Thanks for your help!
