Hi All,
I am struggling with getting Konrad’s DWG Export tool to work properly.
https://forum.dynamobim.com/t/export-view-set-to-dwg
I need to apply the following settings as inputs, but can’t work out how to.
Apply the ‘Automatic - Short’ name setting
Do not export all the views and sheets as xrefs
Select the Export Setup
Here is the code currently:
# Copyright(c) 2016, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Import Element wrapper extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
def ProcessList(_func, _list):
return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def ProcessParallelLists(_func, *lists):
return map( lambda *xs: ProcessParallelLists(_func, *xs) if all(type(x) is list for x in xs) else _func(*xs), *lists )
def Unwrap(item):
return UnwrapElement(item)
folderPath = IN[0]
if isinstance(IN[1], list):
views = ProcessList(Unwrap, IN[1])
views = list(Unwrap(IN[1]))
if isinstance(IN[2], list):
names = IN[2]
names = list(IN[2])
RunIt = IN[3]
def ExportDwg(name, view, folder = folderPath):
options = DWGExportOptions()
views = List[ElementId]()
views.Add(view.Id)
result = doc.Export(folder, name, views, options)
return result
if RunIt:
try:
errorReport = None
# run export
ProcessParallelLists(ExportDwg, names, views)
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
errorReport = "Please set the RunIt to True!"
#Assign your output to the OUT variable
if errorReport == None:
OUT = 0
OUT = errorReport
Thanks in advance
Paul
