Export Alignment Data with Station Equations
I have a cool script that exports to excel Station, N, E, Elevation at any increment or offset from the alignment. However it does not read Station Equations within the Alignment. Anybody ever cracked that nut?
Is this what you’re looking for? A list of station equations?
I also was trying to do this.
Keith
Can you share the dyn file please
GetStaEqns.dyn (4.7 KB)
Hello.
It does not work. Neither the Civil3DToolkit equation node.
Does your alignment have a station equation? If it does not, it will return an empty list.
It works very well now.
Thanks.
Cool, Thanks guys!
Hi @Paolo_Emilio_Serra1 ,
Would this node be added in the next version of Civil3DToolkit?
Thanks.
Hi
I have been trying to figure out how to use this node in my graph’s but don’t understand how.
First i tried to calculate the difference between the RawBack and Station Ahead but it didn’t go well.
Or how should the approach look like when I try to use this in combination with Alignment.CoordinateByStationOffset
I hoped that the circle should be created at the point of station equation but it was created at 1+606
