Creating a Report of Elevation from offset Alignments
I have a problem. I created the This TRK-2 Alignment, Surface, Profile then offset.
When I want to extract the XYZ coordinate of 1 increment.
I use Alignment | Incremental Station Report and
Profile |Incremental Stationing Report
Here is the drawing file. If I can just get the elevation as per station at an increment by using Dynamo it is very helpful.
Maybe there is a bug in Civil3D offset reporting in this case. Because Track 1 have no problem this one is quite a trouble. I am using Civil 3D 2022 by the way.
Drawing2.dwg (1.0 MB)
hi
I didn’t understand you because my language is not good
You may need this
Hi, Thank you very much for your reply.
My goal is to extract Coordinate points in an element or a alignment at 1 increment/interval.
Because I can’t complete the alignment in civil3D offset because of some bug.
May I know how can I utilize the information you have provided.
Thank you very much.
Cheers,
Rod
can you looking at this
and
Hi @hosneyalaa,
Thank you very much for your help.
I have seen this before. But I can’t get the idea for the elevation.
I am trying different ways though.
Cheers,
Rod
HI @Rod.D.Lecetivo
TRY
