Hi there,
I am trying to format my excel output based on values.
I Know bumblebee does that, and I went through a lot of posts about the same issue but couldn’t get any definite answer for my problem. Please help
This is my output
And I have attached my script as well.
Dynamo_Design Option Excel Report & Revit Text List Tool_MK016_Cell overrides not working yet.dyn (256.9 KB)
I want to colour code my Design Option sets and so forth.
So my range is not fixed, hence I can’t use Format excel from bumblebee either.
Please help. Thank you so much !!
@Konrad_K_Sobon Can you please help me with this??
Thank you !!
Hello, an example using Interrop and Python to color cells by values
import System
from System import Array
clr.AddReference('System.Drawing')
import System.Drawing
from System.Drawing import *
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c' )
from Microsoft.Office.Interop import Excel
from System.Runtime.InteropServices import Marshal
class ExcelUtils():
def __init__(self, filepath, lstData, search_values, strRgb):
self.lstData = lstData
self.filepath = filepath
self.search_values = search_values
self.color = eval("ColorTranslator.ToOle(Color.FromArgb(" + strRgb + "))")
def ExportXlsColor(self):
ex = Excel.ApplicationClass()
ex.Visible = True
ex.DisplayAlerts = False
workbook = ex.Workbooks.Add()
ws = workbook.Worksheets[1]
nbr_row = len(self.lstData)
nbr_colum = len(self.lstData[0])
xlrange = ws.Range[ws.Cells(1, 1), ws.Cells(nbr_row, nbr_colum)]
a = Array.CreateInstance(object, nbr_row, nbr_colum)
for indexR, row in enumerate(self.lstData):
for indexC , value in enumerate(row):
a[indexR,indexC] = value
#copy Array in range
xlrange.Value2 = a
# color cells
for cellRg in xlrange:
if cellRg.Value2 in self.search_values:
cellRg.Interior.Color = self.color
used_range = ws.UsedRange
for column in used_range.Columns:
column.AutoFit()
workbook.SaveAs(self.filepath)
file_path = IN[0]
data_values = IN[1]
search_values = IN[2]
ds_color = IN[3]
str_color = "{},{},{}".format(ds_color.Red, ds_color.Green, ds_color.Blue)
obj_xls = ExcelUtils(file_path, data_values, search_values, str_color)
obj_xls.ExportXlsColor()
You can also create the appropriate cell range(s) based on your values.
Hey Mate,
Thank you so much for your input. It worked perfectly if I run it as a separate dynamo script. In which I have to define values.
But when I use the Code in my existing dynamo script using the values generated through script itself, It doesn’t work. Maybe some input issue or something. I am sure, it is just minute away from the solution. Can you please have a look ? I want all the inputs as per the screenshot. It would be awesome. Please Thank you.
Hey Nick,
That’s a great suggestion. I’ll look into it. I was just hoping, somehow it formats the excel based on values than cells.
Thanks though. If nothing works, It will be my last resort.
Update - The Python Code only works if I run it as a separate Dynamo Script. It works as per my needs.
Can you please help me if I could have both scripts in a single script? Please Thank you.
@chhabrat
replace the Data.ExportExcel node by the Python Node.
the Excel workbook must be closed beforehand
import System
class ExcelUtils():
def __init__(self, filepath, lstData, search_values, sheet_Name, strRgb):
self.sheet_Name = sheet_Name
ex.Visible = True
ws.Name = self.sheet_Name
xlrange.Value2 = a
# color cells
column.AutoFit()
file_path = IN[0]
data_values = IN[1]
ds_color = IN[3]
sheet_Name = IN[4]
obj_xls = ExcelUtils(file_path, data_values, search_values, sheet_Name, str_color)
Hey Cyril,
Firstly, I really appreciate your effort to maintain this community of people who wants to learn and providing your input to people who you don’t even know. I applaud that. I am very grateful.
Secondly, I am not sure why isn’t this working out for me.
Dynamo_Design Option Excel Report & Revit Text List Tool_MK016_Cell overrides not working yet.dyn (77.5 KB)
Can you point to anything which I may be missing?
Thanks mate.
Update - @c.poupin Your first python node is working perfectly.
It’s taking List as its input not any string.
But I can’t seem to add Sheet name to your old script. is there any way I can do that?
Also, if I can have multiple inputs of color for different values?
Thank you so much !!!
A solution using a dictionary
import System
class ExcelUtils():
def __init__(self, filepath, lstData, dict_key_color, sheet_Name):
self.dict_key_color = dict_key_color
ex.Visible = True
xlrange.Value2 = a
# color cells
if cellRg.Value2 in self.dict_key_color:
cellRg.Interior.Color = self.dict_key_color.get(cellRg.Value2 )
column.AutoFit()
def convert_to_OLE(ds_color):
strRgb = "{},{},{}".format(ds_color.Red, ds_color.Green, ds_color.Blue)
return eval("ColorTranslator.ToOle(Color.FromArgb(" + strRgb + "))")
file_path = IN[0]
data_values = IN[1]
dict_key_color = {key_ : convert_to_OLE(ds_color) for key_, ds_color in zip(IN[2].Keys, IN[2].Values)}
sheet_Name = IN[3]
obj_xls = ExcelUtils(file_path, data_values, dict_key_color, sheet_Name)
similar topic here
Hello all,
I am trying to Fill multiple Excel Cells with a different unique color (See image below). I would like the cell to be colored rather than have the RGB value. Each line should have a unique color.
[image]
I have looked at BumbleBee but it seems to only work with conditional formatting (see the two sections below). Is there a way or a package to set the color of an individual cell?
BumbleBee Primer
Fill Style: https://konradsobon.gitbooks.io/bumblebee-primer/content/210_fill_style…
Hey @c.poupin Cyril,
It’s Perfect. I can’t thank you enough for your time.
You’re a Legend. Thank you so much !!!
Update -
PS It’s Overwriting the data in the workbook, is there a way, if I run the script creates another sheet instead of overwriting it? Or if the sheet name is already there it overwrites that…?
If you choose not answer I would understand. You have helped me a lot. And I can’t thank you enough.
