Excel Fill Color
Hello all,
I am trying to Fill multiple Excel Cells with a different unique color (See image below). I would like the cell to be colored rather than have the RGB value. Each line should have a unique color.
I have looked at BumbleBee but it seems to only work with conditional formatting (see the two sections below). Is there a way or a package to set the color of an individual cell?
BumbleBee Primer
Fill Style: https://konradsobon.gitbooks.io/bumblebee-primer/content/210_fill_style.html
Conditional Formatting: https://konradsobon.gitbooks.io/bumblebee-primer/content/310_conditional_formatting_overview.html
Have you tried xlsxwriter? Pretty powerful library:
https://xlsxwriter.readthedocs.io/index.html
Hello
a solution to apply a color by row with a Python dictionary and Microsoft API
# coding: utf-8
import System
from System import Array
clr.AddReference('System.Drawing')
import System.Drawing
from System.Drawing import *
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c' )
from Microsoft.Office.Interop import Excel
from System.Runtime.InteropServices import Marshal
xlDirecDown = System.Enum.Parse(Excel.XlDirection, "xlDown")
xlDirecRight = System.Enum.Parse(Excel.XlDirection, "xlToRight")
class Lst_Xls():
	def __init__(self, path, dictcolor):
		self.dictcolor = dictcolor
		self.lsta = []
		ex = Excel.ApplicationClass()
		ex.Visible = True
		lst_xls = []
		workbook = ex.Workbooks.Open(path)
		ws = workbook.Worksheets[1]
		##get number of Rows ##
		rowCountF = ws.Columns[1].End(xlDirecDown).Row
		##get number of Coloun  ##
		colCountF = ws.Rows[1].End(xlDirecRight).Column
		self.fullrange = ws.Range[ws.Cells(1, 1), ws.Cells(rowCountF, colCountF)]
		self.fullvalue = self.fullrange.Value2
	def setRowColorbyDict(self):
		for row in self.fullrange.Rows:
			rangerow = row.Value2
			firstvalue = rangerow.GetValue(1,1)
			if firstvalue in self.dictcolor:
				strRgb = dictcolor.get(firstvalue)
				row.Interior.Color = eval("ColorTranslator.ToOle(Color.FromArgb(" + strRgb + "))")
				self.lsta.append([firstvalue, strRgb])
#dictionary to complete
dictcolor = {"CW_CP":"192,192,255", "CW_SP":"85,168,255", "CW_GL":"0,0,255", "FC_XX":"128,0,64"}
xlspath = IN[0]
obj_xl_lst = Lst_Xls(xlspath, dictcolor)
obj_xl_lst.setRowColorbyDict()
OUT =  obj_xl_lst.lsta
the dictionnary “dictcolor” is to be completed
You are a great programmer! Tres bien! I tried to solve that, too but I could not assign RGB value to Interior.Color section. Why does not it work to pass RGB function in Python?
hello @Deniz_Maral
RGB function is a function for VBA not .NET
Hello Cyril,
but here under .NET you can find it or am I wrong?
It’s a property not a function
an example here
Merci! I did not use ForeColor.RGB… that is problem…
All,
Thank you for your help and comments. A Coworker and I were able to get what we needed. @c.poupin your code was extremely helpful.
The modification is not beautiful but get the job done for now and what we need. I will hopefully clean up the script in the near future.
#https://forum.dynamobim.com/t/excel-fill-color/46984/5
# coding: utf-8
import System
class Lst_Xls():
	def __init__(self, path):
		self.lsta = []
		ex.Visible = True
		lst_xls = []
		#set the start row and start column
		self.fullrange = ws.Range[ws.Cells(startRow, startColumn), ws.Cells(startRow+len(colors), startColumn)]
		index = 0
			if index == len(colors):
				break
			row.Interior.Color = eval("ColorTranslator.ToOle(Color.FromArgb(" + colors[index] + "))")
			index+=1
#Inputs
xlspath = IN[0]
colors = IN[1]
startRow = IN[2]
startColumn = IN[3]
obj_xl_lst = Lst_Xls(xlspath)
OUT = str(len(colors))+' colors added to excel'
Great work, thanks for sharing!
I used it with my MEP system graphics and worked great
Hello, I’m trying this python script, but this is the error, any help?
This appears to be solved in your initial post. Have to tried the solution there?
