Error when using Dynamaps
I get this error "DynaMapsNodesFunctions.LiveFootPrint operation failed. Could not load type
‘Autodesk.Revit.DB.DisplayUnitType’ from assembly ‘Revit API, Version=23.0.0.0, Culture=neutral, PublicKeyToken=null’ when I press on “Push To Dynamo” option in Dynamaps
DynaMaps is not updated for newer versions of Revit (2018+)
I think
I believe it works up to 2022. 2023+ there are unresolved unit type issues.
You can look into the Elk package and Dynamo for Forma as alternatives.
