Dynamap didn'twork
Hello guys I try to make topography with dynamap
but didn’t work.
that didn’t show anything
yellow massage show only
“Warning: DynaMapsNodesFunctions.LiveFootPrint operation failed.
Unable to load type ‘Autodex.Revit.DB.DisplayUnitType’ from assembly ‘RevitAPI, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null’.” this
I don’t know what’s means, can I get some help?
my Dinamo ver 2.10.1.3976
dynamap ver 2019.2.21
Hi @l0903,
There has been a big change in the Revit API for units recently. If Dynamaps has not been updated, it is normal that it does not work for Revit 2022.
Thanks for the reply.
then I upgrade DynamoCoreRuntime2.12.0?
So that means there is no Dynamaps version for Revit 22 yet?
It looks like :
is there a solution today? or is it advisable to install revit 2019?
Hello…probably this one here could be an alternative…
https://apps.autodesk.com/RVT/en/Detail/Index?id=4910606560103189779&appLang=en&os=Win64
Hi @l0903,
I had also faced the same issue and posted about it last year but so far no responses on the issue.
