Dynamaps doesn't work when i click push to dynamo
I tried to model topography using dynamaps but i got an error while running this program
DynaMapsNodesFunction.LivePrint operation failed. Could mot load type
‘Autodesk.Revit.DB.DisplayUnitType’from assemblyRevitAPI, VERSION=23.0.0.0,Culture-neutral, PublicKeyToken=null’.
what should i do?
Hi @muhfslpals ,
I have only managed to get DynaMaps to work on Revit 2019 and 2020 (Haven’t tried Revit 2021). Revit 2022 didn’t work for me so I would assume that it also has the same issues in Revit 2023.
i couldn’t find dynamaps menu on view tab when i run the program with revit 2019 ,have you ever faced the same problem as me?
Are you sure DynaMaps is installed for Revit 2019? Nodes normally turn red when you are missing the package which it comes from.
