I am trying to using the DynaMaps plugin to generate the surrounding context for one of my projects. This is the error I get in dyanamo Warning: DynaMapsNodesFunctions.LiveFootPrint operation failed. Could not load type ‘Autodesk.Revit.DB.DisplayUnitType’ from assembly ‘RevitAPI, Version=[24.0.0.0](javascript:void(0);), Culture=neutral, PublicKeyToken=null’. Does anyone have an idea as to how I can resolve this? Any help is appreciated. Thank you in advance.
Dynamaps hasn’t been updated for the units changes which were required for Revit 2023 and up, and I do t believe it is supported anymore. I recommend looking at the Elk and Dynamo for Forma packages.
Thank you. I will check them out.
