Dear all!
I have a project. let mta3describe my project :
First, i have elements like curves, etc… Second, i will array points on these one with an equal distance. Then, i will create a point with identified XYZ. Then i make line from this point to these one on the elements.( It looks like in the pictures). After that, i create a horizontal plane under the elements that it cut all the lines. So, i have intersection points by the plane and all the lines. Final i make a hermite spline through the intersection points.
When i select some simple elements, it works very well.
But there’s a problem when i select more complicated elements. Please help me to fix it!
Manh Hung
