I’m having some trouble accessing data from an excel file using Dynamo. It’s a fairly complex spreadsheet but the actual data I need is fairly limited - about 20 columns x 150 rows over around 30 sheets.
Every time I try to access the spread sheet I get errors, typically our of memory - is there a way I can only pull the data from specific cells on each sheet rather than having Dynamo read everything?
Additionally I seem to have issues with the inbuilt node reading anything at all…
Anybody got any ideas as to what the problem might be? This is running in Dynamo 2.0.3.
Cheers
K.
