Error message and Revit crashing
Hi everyone,
Every time I open Dynamo in my computer and see this message in the background, Revit crashes. Does anyone know why? Initially that would happen only once, then I would restart Revit + Dynamo and everything would be fine, now every time I start Dynamo, Revit crashes.Thanks!
Same here after window 10 update last month.
I give you a temporary way to use Dynamo:
Every time you open Revit, start with New project (use Structural template) -> Open Dynamo . Then open the project/family you want to work with -> Close New project (via Structural template). Now you can work with your Dynamo.
Looks like it can’t find the camera in which to render…
This may be a similar issue…
Can you create a new issue on dynamo Github so the developers can track…
FYI @solamour @Michael_Kirschner2
Hello @bialmeida - Can you please try download DirectX from here? https://github.com/DynamoDS/Dynamo/wiki/Dynamo-FAQ
Let me know if this doesn’t help!
Hi @solamour
I followed your instruction to install End-User Direct X for Dynamo. It worked in the first day of operation but on folowwing days working, it has been crashed again with the same notification
Hrm, that’s not so good!
Any ideas here @Aaron_Tang @Aparajit_Pratap?
@bialmeida May I also ask what version of Revit this is?
I can’t unfortunately, but I will ask IT and let you know. Thank you very much!
I am working with Revit 2020. Thanks!
Can you check with Structural default template?
If I start Revit with this template for the first time, Dynamo works normally. But if I use another template or my company template, it crashes.
thats an interesting issue.
Cross referencing another post about a similar thing I think.
Hey everyone, it’s actually getting worse unfortunately. I restarted Revit, changed the script, saved it and now it’s corrupt. Since I just changed a very simple node, I am assuming this is related to the previous issue.
Are you using remote control to your desktop??
