Hello, I am days that I try I have this problem: since I made the Dynamo update 1.2.1 to 1.3.0. Dynamo 1.3.0 When I open the computer goes crash, first with Dynamo 1.2.1 did not happen; I have a (Nvidia Geforce M-Window 10) .Revit works but when I open Dynamo always goes crash. I did Window Update, and I’m checking if with older nvidia drivers work, nothing to do. Can someone help me? Thank you
are you working with Revit 2016 or higher? Dynamo 1.3.0 doesn´t work with earlier versions. I don´t know if it would make it crash though…
No, I work with Revit 2017.Revit work but when active Dynamo 1.3.0
It will show the message “The system has detected an error and is about to restart.”
Since there is this version (1.3.0 Dynamo and Dynamo Player), goes in crash; It not happened before with (Dynamo 1.2.1). The only way to operate Dynamo 1.3.0 is to disable the dedicated graphics card (Nvidia Geforce 610m) and to work the integrated graphics card (Intel HD Graphics 4000).Thank you
Hi:
Did you find a solution for this, I have the same issue
