Error in bumblebee writing excel
Hi.
Im havin this error while im writting data to excel
  File "<string>", line 163, in <module>
  File "<string>", line 82, in WriteData
  File "<string>", line 66, in FillData
EnvironmentError: System.Runtime.InteropServices.COMException (0x800A03EC): Exception from HRESULT: 0x800A03EC
   at Microsoft.Scripting.ComInterop.ComRuntimeHelpers.CheckThrowException(Int32 hresult, ExcepInfo& excepInfo, UInt32 argErr, String message)
   at CallSite.Target(Closure , CallSite , ComObject , Object , Object , Object )
   at System.Dynamic.UpdateDelegates.UpdateAndExecute4[T0,T1,T2,T3,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3)
   at Microsoft.Scripting.Interpreter.DynamicInstruction`5.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.LightLambda.Run8[T0,T1,T2,T3,T4,T5,T6,T7,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6, T7 arg7)
   at IronPython.Compiler.PythonCallTargets.OriginalCallTarget7(PythonFunction function, Object arg0, Object arg1, Object arg2, Object arg3, Object arg4, Object arg5, Object arg6)
   at System.Dynamic.UpdateDelegates.UpdateAndExecute9[T0,T1,T2,T3,T4,T5,T6,T7,T8,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6, T7 arg7, T8 arg8)
   at Microsoft.Scripting.Interpreter.DynamicInstruction`10.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.LightLambda.Run5[T0,T1,T2,T3,T4,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4)
   at IronPython.Compiler.PythonCallTargets.OriginalCallTarget4(PythonFunction function, Object arg0, Object arg1, Object arg2, Object arg3)
   at Microsoft.Scripting.Interpreter.FuncCallInstruction`7.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.LightLambda.Run7[T0,T1,T2,T3,T4,T5,T6,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6)
   at System.Dynamic.UpdateDelegates.UpdateAndExecute6[T0,T1,T2,T3,T4,T5,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5)
   at Microsoft.Scripting.Interpreter.DynamicInstruction`7.Run(InterpretedFrame frame)
my dynamo version is 1.2.0.2690 on revit 2017
bumblebee package is 2017.12.1
thanks for help!
Hello, I see 2 issues here:
  • The origin’s string (“a0”) into the ‘BB Data’ node
  • The data’s from “OUT” linked as an input in your ‘File.WriteText’ node.
    I would rather make use of the OOTB ‘Excel.WriteToFile’ node and also use ‘ReadFromFile’ before ‘WriteText’ (+ ‘File.FromPath’ after ‘File.Path’) .
Your input for the Origin is wrong. Excel starts numbering at A1 not A0. Also, your file path is missing a file extension. I am not sure what you are trying to do here. Please read the basics first: https://konradsobon.gitbooks.io/bumblebee-primer/content/
