However, when I tried to do it, I found out that “Generate Test Points” with only 3 inputs and “Sunlighthour Analysis” are not available anymore.
I thought I could use the “Annual Solar Exposure” to replace “Sunlighthour Analysis” node but I couldn’t even get to that step because when I tried out using the new “Generate Test Points by Grid Size” node, I get an error.
I don’t know how to use this node (also do not know how to read/write python yet), what are the borders for and how do I accurately create inputs for this?
hi,archjahzzy,I guess the node “Generate test points by Grid Size” can’t accept the “surface” you select from the model directly. And I’m confused by the input, “testSurfaces” and “Borders” , and their relationships. I’m sorry for can’t tell you more details, I’m also a newbie……
