Does anybody have a clue why am I getting the following error on DynaMaps nodes:
Warning: DynaMapsNodesFunctions. Failed operation LiveTopoPoint.
Not able to load type Autodesk.Revit.DB.DisplayUnitType of assembly RevitAPI, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null
Having this exact same problem, may have to do with this update, where they’ve changed display unit types to Forge Id, apparently for cross compatibility
May be a small fix, but I can’t manually change the units from “Revit” in the initial dropdown menu
Is there any update planned for Dynamps to address this issue, maybe?
Any other workaround?
