You can fix this Erorr?
What is the warning
above the node say?
hello @khang.civil.2000 see this topic
the traceback is really blurry.
the report of the traceback.tb_lineno seem missing in implementation of context manager
I tried but still got the error. Can you help me fix the error? Thank you
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
def get_tinvolumesurface_Vol(vs_name):
global adoc
vsid = None
output = {}
with adoc.LockDocument():
with adoc.Database as db:
bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
btrID = bt.get_Item("*Model_Space")
btr = t.GetObject(btrID, OpenMode.ForWrite)
for oid in btr:
obj = t.GetObject(oid, OpenMode.ForWrite)
if isinstance(obj, TinVolumeSurface):
if obj.Name == vs_name:
vsid = oid
if vsid is not None:
break
if vsid is None:
return "Surface not found"
vs = t.GetObject(vsid, OpenMode.ForWrite)
props = vs.GetVolumeProperties()
for a in dir(props):
try:
output[a] = getattr(props, a)
except:
pass
t.Commit()
return output
OUT = get_tinvolumesurface_Vol(IN[0])
Hi
Using cpython 2,7
@khang.civil.2000 it seems you have indentions wrong on code lines between “vs = t.GetObject(vsid, OpenMode.ForWrite)” and “t.commit()” and also “return output”
