To avod AutoCAD Fatal Error and reveal the transaction error in detail, import traceback and include the try, except, traceback example in the commented out area in the transaction
import sys
import traceback
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Database as db:
## Place your code below
# try:
# except:
# error = traceback.format_exc()
## Commit before end transaction
# t.Commit()
pass
OUT = 0
