Python revit geometry to dynamo / dynamo geometry to revit
So far,
    # Load the Python Standard  Libraries
    clr.AddReference("RevitAPI")
    # Current doc/app/ui
    #Filtered element collector (all rooms)
    rooms = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Rooms)
    #walls = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls)
    #Filter rooms to those with area more than 0 (Unplaced)
    placed , unplaced  = [], []
    for rm in rooms:
    	if rm.Area > 0:
    		placed.append(rm)
    		unplaced.append(rm.Id)
    #Delete unplaced rooms
    delrooms = [doc.Delete(i) for i in unplaced ]
    #Convert Revit elements to dynamo elements
    dyrooms = placed.ToProtoType()
    OUT = placed
Hello @_Vijay
you can only convert Revit GeomtryElement to Dynamo geometry (not an element or iterable), so it is necessary to get the Revit geometry before converting it.
Here is the most common method, but there are others in Revit API
import sys
import System
placed , unplacedIds  = [], []
for rm in rooms:
	if rm.Area > 0:
		placed.append(rm)
		unplacedIds.append(rm.Id)
if len(unplacedIds) > 0:
	iLstdel = List[ElementId](unplacedIds)
	doc.Delete(iLstdel)
outDSGeo = []
opt = Options()
for _room in placed:
	#get Revit Geometry (Inherited from Element Class)
	lstgeoRvt = _room.get_Geometry(opt)
	#transform geometry (Solid) to Dynamo Geometry
	lstgeoDS = [x.ToProtoType() for x in lstgeoRvt]
	outDSGeo.append(lstgeoDS)
OUT = outDSGeo
@c.poupin thank you for the help. I am trying to add the two more nodes here. I tried to take reference from here.
import sys
import System
clr.AddReference("DSCoreNodes")
import DSCore
from DSCore import *
for rm in rooms:
	if rm.Area > 0:
		placed.append(rm)
	doc.Delete(iLstdel)
outDSGeo = []
opt = Options()
	geoDS = [x.ToProtoType() for x in geoRvt]
	outDSGeo.append(geoDS)
#rcpoints = Solid.ComputeCentroid(fl)
#Finding center point of the room
#Flatten the outputs
placedrooms = List.Flatten(outDSGeo, 1)
roomsolids = List.Flatten(placed, 1)
OUT = placedrooms, roomsolids
Update: room tag centred done with help of @Alban_de_Chasteigner 's “Tag Set Location”.
import sys
import System
import DSCore
#Filtered element collector (all rooms tags)
roomtags = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RoomTags).WhereElementIsNotElementType().ToElements()
for rm in rooms:
	if rm.Area > 0:
		placed.append(rm)
	doc.Delete(iLstdel)
outDSGeo = []
opt = Options()
#Relocate room tags to centre
tags = UnwrapElement(roomtags)
locations = UnwrapElement(IN[1])
for tag,location in zip(tags,locations):
	tag.TagHeadPosition = location.ToRevitType()
OUT = roomtags
point = Autodesk.Solid.Centroid(outDSGeo);
why is not working?
Hello @_Vijay
wrong namespace and method (Autodesk.Solid namespace doesn’t exist in Revit API or Dynamo API)
try this
lstCenterPtsDs = [solid.Centroid() for solid in outDSGeo]
The node “Solid.Centroid” is under “Autodesk.DesignScript.Geometry.Solid.Centroid” or something similar. It is under the “DynamoCore” which you have referenced as “DSCore”
import sys
import System
import DSCore
for rm in rooms:
	if rm.Area > 0:
		placed.append(rm)
	doc.Delete(iLstdel)
outDSGeo = []
opt = Options()
rcpoints = [solid.Centroid() for solid in outDSGeo]
#point1 = Autodesk.Solid.Centroid(outDSGeo);
locations = UnwrapElement(rcpoints)
OUT = roomtags
The warning explains that you have given it a list and not a single solid, therefore you need to iterate over this list and then input each element into this.
Check the data structure for outGeo, because it may be a list of a list and you need to iterate over this correctly to then grab the centroid.
Or you may need to do some solid joining then get its centroid, it all depends on what the solid information you are getting and how it is structured in a list.
Hello, here are 2 solutions
opt = Options()
#a solution with extend
outDSGeoA = []
    outDSGeoA.extend(geoDS)
rcpointsA = [solid.Centroid() for solid in outDSGeoA]
#another solution to preserve list structure
outDSGeoB = []
    outDSGeoB.append(geoDS)
rcpointsB = [[solid.Centroid() for solid in listsolid ] for listsolid in outDSGeoB]
Note;
it’s better to learn Python first and then IronPython (environment Net) and understand Revit API :wink:
Very thank you @c.poupin.
This is my 1st python and Revit api attempt .
You helped and motivated me lot. I will keep learning.
I would also add that it is sometimes worth while outputting your data out of python and reading what the structure is. This will help you understand what you need to do.
If you know that the geo from revit is a list you could even possibly do the following as long as you want geoDS out as well as the centroid.
centriodOutput = [solid.Centroid() for solid in geoDS]
outDSGeo.append([geoDS,centriodOutput])
If you only want the centroid out then i would do this
outDSGeo.append(centriodOutput)
