Embedded curtain walls
I have a list of Curtain Walls that are embedded within typical masonry walls. Is there any way to get the ‘host’ wall of the curtain walls?
Or, to go about it the other way - is there a way to find all of the embedded curtain walls for a given wall?
Hi @Wes_Mcelhany
You could use Clockwork package “Element.Inserts” node. It can get embedded walls.
That did the trick. Thanks!
@Wes_Mcelhany Here is how you mark the post as solved when you find solution.
Done. Thanks again!
Is there a way to do the opposite of this? I have a list of embedded curtain walls and I need a list of the walls they are inserted into.
I am also trying to find a way to get the host of an embedded wall. Anyone have any ideas?
