Curtain wall cut with a Basic wall
Hi all,
I have a model where the the wall openings (windows and doors) are modelled as curtain wall. I want to find out which curtain walls are cutting which basic wall so i can filter. Why? I want to subtrack the Type parameter “function” from basic wall and apply that to the same curtain wall. see it as following: Curtain wall is a element and i want to find out which basic wall is the host. Can somebody look into my script a let me know what i am doing wrong?
Wall cuts
thanks in advance
Hi @shahrasa
Try using Element.Host custom node from clockwork package.
I tried that, but it doesn’t work, because walls do not have a host. Usually their are the host.
Thats why I tried to intersect their curves, but that is wrong…when cutted, they don’t intersect
@shahrasa Did you try using Element.Insert node?
No, i will look into this and will let you know if it works
Hi Kulkul,
Sorry for the late reply. Your method worked wonderfully. Thank u so much.
regards Shah
@shahrasa Please mark the post as solved. You’re Welcome!
