This is a general question and personally I don’t know how to deal with it.
Regarding Project North, I wonder if you change the Elevation or if you always leave it at 0. Do you then compensate with levels to get the correct elevation?
If you change, what do you start from, Level 1 finished floor or height at the entrance?
Hi Andreas,
I should been more direct, this thread is not about Dynamo, just how you deal with Project Base Point in projects and if you let Project Base Point’s elevation = 0 or do you change?
Thanks,
I see in one of your picture that project base point is set to an elevation of 72,0200, is this heigt to level 1 or is it to another reference?
