'Elements from Linked File in Room'
Hi All,
I’m trying to select groups in a linked file, can anyone see a problem with the attached tree or files?
Thanks in advance,
Mark
Project-Test-2016 for linking.rvt (2.2 MB)
Project-Test-2016-tobelinked.rvt (2.6 MB)
Hello, the problem lies in your group selection because they are in your linked file. You could try something like this:
or see here:
Thanks a lot for getting back to me, that looks like a great idea.
Unfortunately though, I am looking to select Elements (Groups), not a Category.
Would you know of an alternative node?
The only linked file node I have found is the “Elements From Linked File in Room”, which I have tried in this tree.
Thanks,
Mark
Try All Elements of Type in Document from Rhythm
Update: I still get a null result at the moment, I’ll take a closer look at this later.
There is another method with Room.Contains:
OK, last update, it seems to work with All Elements of Type in Document from Rhythm but you need to add a Flatten node just after :relaxed:
Thanks for helping, but I can’t see how you are getting groups from a linked file?
I can get groups from the host file, it is the linked file that’s failing…
Thanks,
Mark
Here is what I did:
Thanks,
Awesome, that works!
Interesting, that process still gave nulls if the levels weren’t being used…
I wonder whether the problems are to do with the way that levels are interrogated by the nodes?
Thanks hugely,
Mark
I’m trying your solution but its not working.How can I solve this?
Thanks,
Bikash
Please start a new thread for a new question. Also, you are NOT doing what the solution posted here suggests. I recommend you try that solution EXACTLY again, and only when that doesn’t work, post a new question.
