Elements from linked file
How can you select all elements of category in linked file?
Hi, existing threads like this could help to get started:
use python and modify Built in category inside;
Preformatted textimport clr
Import ToDSType(bool) extension method
Import geometry conversion extension methods
Import DocumentManager and TransactionManager
Import RevitAPI
clr.AddReference(“RevitAPI”)
clr.AddReference(‘DSCoreNodes’)
import DSCore
from DSCore.List import *
app = uiapp.Application
lnks = FilteredElementCollector(doc).OfClass(RevitLinkInstance)
out =
for i in lnks:
doclnk = i.GetLinkDocument()
coll = FilteredElementCollector(doclnk).OfCategory(BuiltInCategory.OST_StructuralColumns).WhereElementIsNotElementType().ToElements()
out.append(coll)
Start Transaction
#End the Transaction
OUT = out
Hi @Kjell_Vidar_Andersen
there are nodes in Archi-Lab package to do exactly that :
That worked, thanks :slight_smile:
What that “Code Block” in the middle does?
Thanks.
Weighing in after two years:
result =
for doc in _linkDoc:
result.append(…
This will basically ‘loop’ through all linked models in a list that you want to feed to it. The Archilab Get Documents node will do nicely, with a list.clean on the Link Doc output.
Question: how do I get the family instances from this? I only get the basic classes as a result (I deleted the filter in my version)
