I am trying to sort and group all my pipe hangers into groups of the same Hanger Type, Size and Rod length and apply a sequential number to each “group”. FIltering and sorting seem to be working but the renumbering part is failing, the Element.SetParameterByName is giving me a error of "Dereferencing a nonpointer.
What do i need to do to get this working?
Hi @Peterpiper
You need to connect elements to setparameter input element right now your connecting strings.
Yep try using the sorted list output rather than the sorted keys output
Try connecting the bool mask from all elements of category
Found another thread and fixed my own problem - Controlling visibility parameters in titleblocks
I was using “Sheets” instead of “Title Blocks” at the front and was not using binary control 0/1 in a code block for ON/OFF at the set Parameter node.
Works now
