Good morning, everyone. I’ve encountered the following problem. I need to change the value of a parameter for individual elements, but when I select the next one, it also changes the previous one. Why is that? First, I selected item 521943 and modified its parameters; then I selected item 521945, but it also selected 521943.
It’s hard to say only by this screenshot what’s going on,
But I guess it could be due to element binding thing in Dynamo. In this case reopening of graph could help after setting the parameters for each element
If it is Element binding you could also use the Dynamo Player to get around that.
But can’t you set the Parameter in one go instead of one by one?
EDIT
After having a second look i think it is because of Lacing.
It didn’t work even in automatic mode, thank you
