Hi!! there~~~~
Is there any solution to change mutiple parameters at the sametime
the node “element.setparameterbyname” is a separate way to change
i don’t want to change each mutiple parameters because it
takes a lot of time…
the number of parameters is 10
and the number of elements to change is 200 ㅠㅠ
give me a tips please…
Adjust the list lacing and levels and it can set as many parameters at once as you would like.
oh thank you your reply
but i can’t understand… ㅜ
For example, I want a way to group the values to change for each parameter name into a single list.
Now the list of parameter values are the values to change for one parameter.
This is going to sweep by putting the parameter values to be changed in one element at once.
thank you… ㅜㅜ
have a nice day
@jacob.small
@JustinStirling
