i have created a dynamo script which can select all elements of my choice and than i want to fill the same parameter to all the elements which they had to take from only one element which i already filled that value i want that same value to all the elements how can i do that
i attached an image of my current script. as you can see in that dynamo is filling value only in first element.
can someone please help me out on that.
Hi @Hiteshhirani234,
Just by changing the lacing of the node to “longest” or “cross product”, the script should work.
That said, you know that for your purpose you can also use the simple OOTB node “Element.SetParameterByName”, right? Maybe this one, even set to auto, will perform in the way you are looking for.
