I think i found a bug with the element.overrideinview node.
The script that i made will hide all the elements in the current view but when i want to use it again in a other view it won’t work and wil give met the error “Warning: Element.OverrideInView operation failed.
The view type does not support Visibility/Graphics Overriddes.”
The way my script find the elements is by searching with the spring node collect elements in view in a different 3D view which will have all elements of the project.
Can someone give me any advice so i can run the script multiple times instead of close the Revit model everytime i want to use this script in a view?
Run in the Dynamo Player and click the refresh after each time you run it. The other thing you can do it connect a boolean to refresh on the springs.collector node. then just toggle between true and false each time you run the graph. (eg. run with true one time, and false the next)
Thanks a lot Jacob and Scrowe for replaying!
I don’t know exactly what the problem was but today it is working fine again en I will certainly refresh the dynamo player for every script I use from now on, just to be sure.
