Hi I am new to the forum and to Dynamo and was hoping to get some help with this script I have tried to make.
It made it following along with a video on Youtube and the purpose of the script is to highlight elements based on parameter values. I followed each step in the video and think i have each section done correctly however when I run it I get an error on the Element.OverrideInView node. I am stuck on how I can get this to work, any ideas on what the issue might be?
Thanks in advance
This is the error I get on 5. Override Elements
Hey @bertilak welcome to forum
Here’s your solution:- just take wire from 1st group(all elements of category in view) and connect it in 3rd group at the place of list in List.FilterbyBoolMask and it’ll work perfectly.
What u did is you gave strings in Element.OverrideInView where the node is expecting elements because from filter list is coming as strings instead we need elements.
Regards,
BM
Thats great, it works now. Thank you.
@bertilak That’s great, Please mark as solved as it helps community to understand it’s resolved.
Regards
Bm
