Element Geometry - Round to Rectangular Duct fitting
how we can generate such element’s geometry?
I’m trying to get surface area of duct fittings
sample- duct fitting.rvt (6.6 MB)
Can you post an RVT model with the geometry in question? There is likely a work-around but which one to go with is a bit difficult to advise on without first trying a few things.
What happens if Try element.solids?
@jacob.small sample uploaded.
@pyXam
@vishalghuge2500 ,
a workaround is boundingbox
grafik
Try something here could probably work
or an alternative way could be rebuild :wink:
which packages have this node ? Can you show me ?
here is some options
Sorry, i mean this node
århh yeah ;)…synthezise toolkit
apologies for resurrecting an old comment, but I tried to redraw this fitting using your method and had a few questions.
  1. How do I see a 3d version of the new loft?
  2. How do i use that new loft to calculate the surface area?
you will see the geometry in dynamo canvas ,probably you need zoom to fit…maybe
we have a surface area node OOTB for that or just in a codeblock
