I am working on an electrical calculation that pulls data from shared and system parameters from “Electrical Circuits” category. Dynamo is able to pull all of the necessary information, I am able to process everything I need, however I cannot get the resulting voltage to place without converting:
Example: Resulting voltage to be placed in “TP DYN - ACCUM VOLT DROP” shared parameter reports as 4.19V in Dynamo (correct value) and when looking at the schedule in Revit, it reads 0.4V. Same with the sample circuit voltage I pulled reads “5166.67…” for 480V.
I am quite new to Dynamo, does anyone know if I am overlooking how Dynamo reads voltage / conversions?
Thanks again.
From my testing, the multiplier does not seem to be a constant for different voltages. My solution is not ideal, but what I ended up doing is making the parameter unit-less in Revit and used a calculated value to convert to volts (multiplied by a 1V parameter) and divide out for resulting percent in Revit. If anyone knows of something that works with voltage units, I am sure we will end up running into this issue again without an available work-around.
