Dyno - how to create dialog box to select file from path
Hi all,
I’ve managed to create buttons on the toolbar for some of my dynamo codes but I having problems with a certain codes that contains the select file path node. Is there a way of displaying a dialog box for the file path once I’ve clicked on the button on the toolbar?
I apologise in advance I’m a complete newbie to Dyno.
Regards
Hi @James_Washbourne
You can use @john_pierson custom node Rhythm.TextBoxInput Is there a user interface?
Or @Mostafa_El_Ayoubi data shapes nodes https://data-shapes.net/2016/11/03/multi-user-input-form-with-dynamo/
Kulkul,
Thank you very much! It’s exactly what i’m after, do you know if there something similar for selecting model elements?.
Thank you again
Regards
