DynamoSandbox not starting
Yesterday I could start DynamoSandbox (2.0), but today it’s not starting.
Dynamo in Revit is working normally.
Anyone knows why it’s not starting?
Restart your cpu, then try opening it again. If it doesn’t come up check task manager to see if it’s hung on start of idling at 0%. If idling choose ‘go to’ and hit alt+space, then m, then any arrow key and move the mouse.
I restarted my cpu. It still doesn’t show up. The proces starts, but then ends in 2 seconds without showing up in the task manager as application.
Any AV/ASW changes? Are you in a native desktop environment or virtualized? Windows version?
I had a similar issue once and it came down to me only having dynamo revit installed and not dynamo core installed.
Go to control panel then check what programs are installed and see if Dynamo Core and Dynamo revit is installed. If you do not have a dynamo core within the list, i would suggest you reinstall dynamo.
What do you mean with as/asw? I am using Windows 7. It worked yesterday
AV/ASW = Antivirus / AntiSpyware - your digital security suite.
No changes on that. I ran Visual Studio on the proces, got an error. Will share this tomorrow.
Verzonden vanaf mijn Samsung Galaxy-smartphone.
-------- Oorspronkelijk bericht --------
yes please share the exception.
This is the exception I got when running Visual studio on the process Sandbox.
ASMBASE223A.dll exists, but I can’t find the .pdp.
I think it’s solved by Dynamo Core 2.3 Not Running
I did a full reinstall. First time not working, after reading the post I did another clean and reinstall after unzip with 7zip.
