After some time seems like dynamo got sick. And it wont open any saved file anymore.
It happens in revit 2023.
This is what it shows:
and in the background i see that it opens file, but all used notes location in one place and won’t work.
It is happening with every file i try.
But if i will create new one it will work ok until i want to save it and i will not able to open it again.
This problem start after trying update some packages to last version. But even after trying to reinstall them it wont work.
All dynamo files open normally in revit 2024.
Restart your CPU.
Open Dynamo.
Start a new file.
Put a single number slider in it.
Save the file as ‘init’
Close the file.
Copy the ‘init’ file.
Rename the copy to ‘first save’.
Open ‘init’ and let the issue reproduce.
Save the file.
Close the file and Dynamo.
Rename the copy to ‘second save’.
Post all files and the Dynamo log file from the session to the forum or the Dynamo Github.
Hi! It seems the issue might be related to Dynamo’s compatibility with Revit 2023. I recommend checking for specific updates or patches addressing this problem. Good luck in resolving the issue!
