GOOD WORKING EVERYONE
How to make a solidified profile inside the surface, for example, we throw steel profiles under a roof free forum surface, but the profile surfaces do not hold each other, so how can we get rid of this problem?
How do we hem the profile surfaces
If we pay attention to the node points in the link I have given in the appendix, how do we do it the same way
YÜZEY ÇELİK MODELLEME 3.dyn (86.5 KB)
Looks like a variable profile rotation issue.
How about offsetting the ‘solid’ frame geometry using the surface normal vector at the point closest to the intersection point to make the support lattice?
Surface.Thicken would likely be how I likely approach this the first time out.
I want to use structural profiles
but if I have to, I will have to do it with solid modeling
I also like to use structural peofils because I use revit advance steel together
I think you may need an adaptive component controlled by two curves then as the rotation isn’t constant.
