Hello
I have a dynamoscript that cleans files from views, sheets, links etc before we send files to consultants. It runs fine on my pc, takes around 5 min. On other machines (same type) it starts but never finish.
The scrips is located on a server, I,ve tried copying the script to the desktop on other persons pcs but with the same result.
Best regards
Are you running them on the same model with the same conditions? Are there big differences in available system resources (ie: your machine has nothing else open, the other already has 30 gb of .rvts open; does one machine have 10 gb of hdd available and the other 1mb?)? Is the hardware specification (processor, ram, hdd) the same on both?
Hello Jacob!
Thanks for replaying. I finally found out why it didn’t work. I replaced the python node with the “SetDifference” node and it worked. Also we had different dynamo versions. However, I can’t understand the reason why the python node faild for the others. It just produced an empty list for them.
You have your node in IronPython. The coworker is in a newer build, after the point where IronPython was removed from the system. Opening the graph on their system should clearly surface the warning and allow you to resolve quickly.
