Dynamo script -Not running -just showing RUN STARTED
when the Dynamo script is allow for run …it is not running …it is just showing there run started… what may be the reason for that.
hi
this usually happened whrn you have undone task in the revit, for example there is a window opened like view template you need to finish with it and close it before
Hi Khuzaimah, thanks for your reply!
