Hi
When I open Dynamo in Revit 2023 it take about 5-10 min to open and when it is open it run really slow. Slow, when selecting nodes, slow, then searching etc. It’s working fine in Revit 2024.
I have tried to follow all suggestion I could find in the different topics about the issue in here and also other places, but nothing has helped.
what I have done:
- Removed all package
- Disable all Revit plugins
- Reinstall Revit 2023.1.3
- Disable loading packaged both built-in and custom in package manager
I do not use any network location paths, so all locally on my pc
I have copied dynamo log, but dont see where it should be wrong if any
Dynamo log started 2024-02-12 14:38:31Z
2024-02-12 14:38:32Z : Python template set to default.
2024-02-12 14:38:33Z : launch darkly initalized
2024-02-12 14:38:33Z : LD startup time: 668
2024-02-12 14:38:33Z : <<<<>>>>
2024-02-12 14:38:33Z : feature flag exe starting
2024-02-12 14:38:33Z : {“graphics-primitive-instancing”:false,“testFlag”:false,“EasterEggIcon1”:false,“EasterEggMessage1”:“NA”,“IsTSplineNodesExperimentToggleVisible”:false,“CER”:false,“NodeAutocompleteMachineLearningIsBeta”:true,“CER_v2”:true}
2024-02-12 14:38:33Z : EasterEggIcon1 is false FROM MODEL
2024-02-12 14:38:33Z : EasterEggMessage1 is disabled FROM MODEL
2024-02-12 14:39:04Z : Dynamo – Build 2.16.2.5624
2024-02-12 14:39:05Z : System.InvalidOperationException:
2024-02-12 14:39:05Z : There already exists an AlsoKnownAs mapping for DSCoreNodesUI.Logic.If.
2024-02-12 14:39:05Z : There already exists an AlsoKnownAs mapping for If.
2024-02-12 14:39:05Z : Duplicate migration type registered for SunPathDirection
2024-02-12 14:39:06Z : AnalyticalAutomation.dll,M:AnalyticalAutomation.AnalyticalElements.AnalyticalPanel.BySurface(Autodesk.DesignScript.Geometry.Surface,System.Boolean) {0} is missing some XML documentation tags.
2024-02-12 14:39:06Z : The folder ‘C:\Program Files\Autodesk\Revit 2023\AddIns\DynamoForRevit\Built-In Packages\Packages’ does not exist
2024-02-12 14:39:06Z : Dynamo will use the package manager server at : https://www.dynamopackages.com
2024-02-12 14:39:06Z : C:\Program Files\Autodesk\Revit 2023\AddIns\DynamoForRevit\Built-In Packages\Packages was not scanned for packages because a preference setting disabled loading from that location."
2024-02-12 14:39:06Z : C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\2.16\packages was not scanned for packages because a preference setting disabled loading from that location."
2024-02-12 14:39:06Z : C:\ProgramData\Autodesk\RVT 2023\Dynamo\2.16\packages was not scanned for packages because a preference setting disabled loading from that location."
2024-02-12 14:39:06Z : DynamoPackageManager (id: FCABC211-D56B-4109-AF18-F434DFE48139) extension is added
2024-02-12 14:39:06Z : Backup files timer is started with an interval of 60000 milliseconds
2024-02-12 14:39:06Z : SYSTEM:Environment Path:C:\ProgramData\Autodesk\Revit\Addins\2023\InfraWorks;C:\Program Files\Autodesk\Revit 2023\AddIns\SteelConnections;C:\Program Files\Autodesk\Revit 2023\en-US;C:\Program Files\Autodesk\Revit 2023;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Program Files\Microsoft SQL Server\120\Tools\Binn;C:\Program Files\Common Files\Autodesk Shared;C:\Program Files\Microsoft SQL Server\150\Tools\Binn;C:\Program Files\dotnet;C:\Program Files\Common Files\Autodesk Shared\Advance;C:\Program Files (x86)\Common Files\Autodesk Shared\Advance;C:\Program Files\pyRevit-Master\bin;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn;C:\Users\sfi\AppData\Local\Programs\Python\Python312\Scripts;C:\Users\sfi\AppData\Local\Programs\Python\Python312;C:\Users\sfi\AppData\Local\Microsoft\WindowsApps;;C:\Users\sfi\AppData\Roaming\pyRevit-Master\bin;C:\Users\sfi.dotnet\tools;C:\Users\sfi\AppData\Local\Programs\Microsoft VS Code\bin;C:\Program Files\Autodesk\Revit 2023\AddIns\DynamoForRevit
2024-02-12 14:39:07Z : RENDER : Rendering Tier: 2
2024-02-12 14:39:07Z : RENDER : Pixel Shader 3 Supported: True
2024-02-12 14:39:07Z : RENDER : Pixel Shader 4 Supported: False
2024-02-12 14:39:07Z : RENDER : Software Effect Rendering Supported: True
2024-02-12 14:39:07Z : RENDER : Maximum hardware texture size: 16384,16384
2024-02-12 14:39:37Z : RENDER : Rendering Tier: 2
2024-02-12 14:39:37Z : RENDER : Pixel Shader 3 Supported: True
2024-02-12 14:39:37Z : RENDER : Pixel Shader 4 Supported: False
2024-02-12 14:39:37Z : RENDER : Software Effect Rendering Supported: True
2024-02-12 14:39:37Z : RENDER : Maximum hardware texture size: 16384,16384
2024-02-12 14:45:10Z : Documentation Browser (id: 68B45FC0-0BD1-435C-BF28-B97CB03C71C8) view extension is added
2024-02-12 14:45:10Z : DynamoManipulationExtension (id: 58B0496A-E3F8-43D9-86D2-94823D1D0F98) view extension is added
2024-02-12 14:45:10Z : Properties (id: 28992e1d-abb9-417f-8b1b-05e053bee670) view extension is added
2024-02-12 14:45:10Z : Graph Node Manager (id: F76F4274-537D-4782-B1E9-27E8FDE2186F) view extension is added
2024-02-12 14:45:10Z : LibraryUI - MSWebBrowser (id: 63cd0755-4a36-4670-ae89-b68e772633c4) view extension is added
2024-02-12 14:45:10Z : Graph Status (id: 3467481b-d20d-4918-a454-bf19fc5c25d7) view extension is added
2024-02-12 14:45:10Z : Notifications (id: ef6cd025-514f-44cd-b6b1-69d9f5cce004) view extension is added
2024-02-12 14:45:10Z : Package Details (id: C71CA1B9-BF9F-425A-A12C-53DF56770406) view extension is added
2024-02-12 14:45:10Z : PackageManagerViewExtension (id: 100f5ec3-fde7-4205-80a7-c968b3a5a27b) view extension is added
2024-02-12 14:45:10Z : Python Migration (id: 1f8146d0-58b1-4b3c-82b7-34a3fab5ac5d) view extension is added
2024-02-12 14:45:10Z : Workspace References (id: A6706BF5-11C2-458F-B7C8-B745A77EF7FD) view extension is added
2024-02-12 14:45:11Z :
Welcome to Dynamo!
2024-02-12 14:45:11Z : 00:05:33.2105794 elapsed for loading Dynamo main window.
2024-02-12 14:45:41Z : EasterEggIcon1 is false from view
2024-02-12 14:45:41Z : EasterEggMessage1 is disabled from view
2024-02-12 14:45:41Z : Browser Loaded
2024-02-12 14:45:42Z : WPF Render Mode: SoftwareOnly
2024-02-12 14:46:12Z : Saving C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN …
2024-02-12 14:46:12Z : Backup file is saved: C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN
2024-02-12 14:50:43Z : Clearing workspace…
2024-02-12 14:58:17Z : ViewExtensionCommandExecutive ( UniqueId: d80ef046-ac5f-4fc2-92f4-96a3516d5bcb, Name: LibraryUI - MSWebBrowser, commandTypeName: CreateNodeCommand )
2024-02-12 14:58:56Z : ViewExtensionCommandExecutive ( UniqueId: a47a248e-fce0-472f-ab2c-12dbdd55816d, Name: LibraryUI - MSWebBrowser, commandTypeName: CreateNodeCommand )
2024-02-12 14:59:26Z : Saving C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN …
2024-02-12 14:59:26Z : Backup file is saved: C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN
2024-02-12 15:00:34Z : Saving C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN …
2024-02-12 15:00:34Z : Backup file is saved: C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN
2024-02-12 15:01:07Z : Saving C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN …
2024-02-12 15:01:07Z : Backup file is saved: C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN
2024-02-12 15:02:30Z : Saving C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN …
2024-02-12 15:02:30Z : Backup file is saved: C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN
2024-02-12 15:03:07Z : Saving C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN …
2024-02-12 15:03:07Z : Backup file is saved: C:\Users\sfi\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN
