I am new to revit and dynamo, why does dynamo load and run so slow on an educational download?
Michael
Michael
i think you will need an older build, like 0.8 something like that…
can you not switch to a newer dynamo ? or using Sandbox at his latest version ?
https://dynamobuilds.com
I saw your other post, assume that your version of Revit is 2024, not 2014.
Hope your issue with Dynamo latency when open it will be solved. I had the same issue in Civil 3D 2023 earlier this year and it where suddenly fixed, but I don’t know how. Hope it will be that smooth for you as well.
Thank you for the response, with a bit of juggling, things seems to have worked out.
Got good advice on the forum. Patience and persistence.
Michael Wickerson
