Dynamo running on opening project
Hi all,
In the past days if I remember it correct you could automatically load and run LISP routines in AutoCAD by “ss;startup” or something like that.
Is it posible to do this in Revit with Dynamo files?
So when I open (or start) a project. I would like, that also a certain dynamo routine is loading and running. This instead of constantly opening dynamo when opening project.
You can use a keyboard shortcut to launch dynamo if you want. Will still have to load the dyn yourself though.
checkout https://github.com/andydandy74/DynamoAutomation - you might find out how to use journals for something like this.
Thank you for your responses…
Not quite what I was hoping for :wink:
