Hi, is there a way to start Dynamo each time Revit starts?
Try this in a .bat file and point your revit launching shorcut to it
palce the .bat file at the root on your HD
@echo off
cd "C:\Program Files\Autodesk\Revit Architecture 2013\Program\"
start /max Revit.exe
cd "C:\Autodesk\Dynamo\Core\"
start /max DynamoSandbox.exe
thanks but it does not work. as sandbox, references are missing, and it’s not pointing to the document. I will look in the API documentation.
I’m not sure if it’s possible to start it automatically. However you can always add a keyboard shortcut, so that you don’t have to go to the add-in tab every time.
Hope that helped Julien!
yes sure! thx. my query is more about users, as I want to learn them everyday use of dynamo. revit starts so dnamo starts. should be possible as other addin do so. will look later at this.
des pistes
