I want to use Dynamo with Revit to create tools, such as a tool that "extends columns to the base offset of a user-specified wall"
but I don’t want it to be fully automatic, I want the user to be able to select a bunch of columns, and then press a tool button, and have code prompt the user to select a target wall to extend the columns to.
So,
- Can dynamo make code-snippets into Revit buttons on a custom ribbon interface tab?
- Can dynamo prompt the user to select something, wait for them to do so, and then use the active selection for an algorithm?
- Can dynamo incorporate error handling (so that if the user selects the wrong element type, Revit/Dynamo displays an error message)?
              Sounds like you are just getting started with Dynamo.  Check out the Dynamo Primer as it has a lot of information on there that can help you out.
In Regards to your questions.
- You’ll need to write C#/VB with Visual Studio or equal  in order to add true Revit button/Commands/Interfaces.
- You don’t need to build it like this, you can select your columns and wall that you want to extend all at the same time.   Look into “Select Model Elements” , “Categories” and get/set parameter by name nodes
- You can incorporate error handling of sorts especially if you build with Python (excluding error messages like the ones u see within Revit), but for what you need to do, it’s not required to prompt the user as you can isolate the wall and columns with node logic.
Take  a look through the primer and examples and that should help you get started.
Cheers,
Mattt
              Thanks Matt, you are right that I am new, I will take a look at the primer
One followup question though, are there any tools to convert from Dynamo nodes to DesignScript and then convert DesignScript to some language like C#/VB that I can use for a revit command?
              This has been asked previously.
Check out:
https://forum.dynamobim.com/t/how-to-convert-from-dynamo-to-c/4858
Also if you are going down this road, check out Harry’s @BoostYourBIM training on C# and Revit.  I found it very useful.
https://www.udemy.com/revitapi/
              Unfortunately the link in the post to that thread shows someone creating a Dynamo script, and someone creating a C# script afterwards that does the same thing, with absolutely no clues as to how the translation was accomplished, so I must conclude it was done manually, using dynamo merely as a visual guide… which is not helpful at all to someone who isn’t a C# master.
              There is no easy button that I’m aware of sorry.
Maybe check out a C# course to get some of the basic’s as you don’t need to be a master to create simple UI in Revit if Dynamo doesn’t have the pretty interface you are after.
Happy Coding,
Matt
Select a node and on the right click menu, pick Node to Code
              Have a look at Spring Nodes.  There are a few nodes in there that generate pop-up windows (Springs.List.DropDown and Springs.List.DragDropReorder) and some others that generate instructions on the lower left corner of Revit (prompting you to pick something - See Springs.SelectInRevit and Springs.SelectLinkedElements).  If you dissect the Python code inside of those nodes, you can likely generate exactly what you are trying to get for #2 and #3.  I have had some luck using similar methods to make Checklist pop-up windows.
